panel over radio, ac/heat controls
It comes off fairly easy but it's all attached. When the panel comes out the temp controls and the stereo comes with it. U have to pull the trim piece that is around the shifter. Then remove the two screws that hold the ash tray. When the ash tray is removed u will see two screws that hold the radio faceplate. Remove them. Last there is a 10mm bolt holding the side of the radio. You have to go through under the dash on the drivers side and locate the 10mm bolt and remove it. Once removed the whole unit can b removed.
