radio, clock, & stearing wheel controls issues
Old Jan 6, 2009 | 04:16 PM
Zeeser's Avatar
Default radio, clock, & stearing wheel controls issues
I have a 2004 Mazda6. I had to let the car sit for a little more than a week and the battery went dead (an issue I need to figure out since it shouldn't have died...new battery & nothing that should've killed it). Since then, the radio functions and the displays function, but none of the radio buttons work yet I can use the ***** to tune in different stations & change the volume (and turn it on & off). I can't set any of the preset, use the seek or scan button, change the track on the CD player, etc. The clock works, but I can't set it to have the correct time. The button for the outside temperature reading doesn't work so I can't turn that on (ASB button I think it is). Then, none of the buttons for the radio on the steering wheel work, yet, I can use the buttons for the cruise control on the right side of the steering wheel. Anybody have any ideas??
Old Jan 7, 2009 | 11:44 AM
herbaklez's Avatar
Default RE: radio, clock, & stearing wheel controls issues
your answer is here:
https://www.mazdaforum.com/m_81258/m..._/tm.htm#88488
Old Jul 9, 2021 | 11:06 AM
rmpromo's Avatar
Default Did you ever find the problem? Mine is doing the same thing.
Did you ever find the problem because mine is doing the same thing
Old Jul 10, 2021 | 02:44 AM
Try disconnecting your battery, leave it for 15 minutes, reconnect battery & see what happens.
Old Jul 10, 2021 | 05:50 AM
rmpromo's Avatar
Default Radio cruise control and airbag on steering wheel not working
I have tried that numerous times and it doesn’t work.
Old Mar 6, 2024 | 01:44 PM
Ansev's Avatar
Default djdj
Did you ever find the answer?
eyroys
Apr 1, 2013 07:55 PM
white2003
Oct 26, 2009 01:28 PM
Zeeser
Jan 15, 2009 06:10 AM
sixxtring
Jun 29, 2008 05:31 PM
