tail lights
Old May 13, 2006 | 02:31 PM
isl_cruiser's Avatar
Default tail lights
i recently bought a 87 gxl...and a few nights ago i was pulled over for having no tail lights...i didnt know at the time, and now that ive looked into it i have no reverse lights eaither....ive checked all the bulbs, and as much of the wiring as i can (hard to get too) so now im thinkin it might be the switch...if anyone can help[ me on finding the switch, or has any other suggestions, they would be greatlly appriciated
Thanx...peace
Old May 15, 2006 | 06:47 PM
babyhuey's Avatar
Default RE: tail lights
Reverse light out are probably from a failed switch in the transmission if the bulbs check ok. Switch is on the left or drivers side of the transmission towards the rear. Think it has four wires coming out of it but not positive, May only be two. The two for reverse lights are Black w/ Yellow stripe and Red w/ Green stripe on the harness side. Try disconnecting each wire and using a jumper to short between these two wires with key on. If reverse light no come on then switch is bad. Easy replace with an adjustable wrench but don't forget the gasket.
On the tail lights. Do the front marker lights and dash illumination lights work or are they also out? If front markers and interior dash light are all not working also then check the 15 Amp 'TAIL' fuse in the underdash fuse box.
Old May 15, 2006 | 10:35 PM
87 turbo II's Avatar
It seems the switch would have the headlights, dash ligths, and marker signals not working eother, but you're in luck. I rmeember hearing taillights often don't work because of bad grounds, maybe that can help.
Ransack
Jun 23, 2022 09:43 PM
matty
Jan 3, 2006 12:44 AM
the_gray_mazda6
Nov 30, 2005 12:36 AM
meggzi07
Jul 21, 2005 04:13 PM
meggzi07
Jun 2, 2005 06:36 PM
