uneven breaking
Old Dec 29, 2013 | 02:21 PM
toobrokefordodge's Avatar
Exclamation uneven breaking
I bought my car about a month ago and just changed front pads and rotors cause they were bad! Passenger side had no pad left and a huge groove among others on the disk, drivers side the pad looked about new but the rotor was grooved. With the new pads and rotors the pass side barley went on and i had the caliper depressed the WHOLE way. Since the change the pass side burns while I'm driving and shows alot more wear and heat than the driver's side. Could this be from the pads being in the wrong order? Something with caliper travel? Or anything else you guys could think of? Thanks!
Old Dec 29, 2013 | 03:56 PM
racer662009's Avatar
Sounds like u need a new caliper. Did u happen to notice if the slides on the caliper were rusty?
Old Dec 29, 2013 | 06:10 PM
No they were fine but it did seem like it had some wobble where it slides. When I went to check it again it was tight but prolly just because I had used the brakes
Old Dec 30, 2013 | 08:03 AM
Juanky's Avatar
the calipers might look good, but if there is some corrosion inside the piston cylinder or the piston, you will have problems. and you cant see that unless you remove the caliper piston. i think you have a bad caliper. i would remove the piston, clean all and put it back together. or just replace it. it all depends on the mood at that moment. also, replace all the brake fluid.
Old Dec 30, 2013 | 09:27 AM
Thanks I wasn't in the mood to pay 50 bucks for a new caliper so that's why I asked lol but in pretty sure I need one
backman180
Apr 25, 2011 06:20 PM
rbdome
Jul 15, 2010 06:52 PM
grapeape
Jan 22, 2009 11:18 PM
mikeryan161
Oct 1, 2006 07:36 PM
ATL
Mar 6, 2006 12:08 AM
