Turbo question for 01 protege lx 2.0
Old Jan 16, 2011 | 05:04 AM
eromaes's Avatar
Default Turbo question for 01 protege lx 2.0
i was wondering if anyone has bought any turbos for the 2.0 im wanting to turbocharge mine but need some helpful ideas on what i should do to it first or how much psi i can run off stock motor. just ideas and anywhere i can buy a turbo kit.
thank you =)
Old Jan 16, 2011 | 05:16 PM
eromaes's Avatar
also im lookin for something around 2 grand or under for turbo kit.. i want a bolt on but the only one's ive seen is around 2500 but i dont want a ebay turbo kit unless it will actually work with no complications.. im not trying to go big or anything just around 5 or 6 psi
Old Jan 16, 2011 | 08:48 PM
wsoape281's Avatar
a stock msp turbo and management will fit the bill. you just need to find someone selling everything that you need. at 5psi, you could just run a hot air set up and run premium gas on a stock msp ecu.
you need the turbo, ecu, manifold, s and j pipes, custom intercooler set up if you want to run one, intake tubing, blow off valve, etc. you can double the stock wheel horse power with 8 psi, so 5 is plenty just to bolt up and enjoy.
Old Jan 16, 2011 | 09:21 PM
shipo's Avatar
Hmmm, that strikes me as not being possible. Why? Because standard atmospheric pressure at sea level is 14.696 psi, and by bumping the absolute manifold pressure by 8 psi, you would be effectively increasing engine output about 54%. So, with only a 54% bump in engine power, how does wheel horse power approach anywhere near double?
Old Jan 16, 2011 | 10:03 PM
eromaes's Avatar
im just looking for a kit.. this is what i have found so far that im more than likely going to get.. let me know what you think
http://www.raceinspired.com/p-28200-...1998-2003.aspx
wayne84
Jul 27, 2022 09:48 AM
D2R
Dec 2, 2010 11:08 PM
bluemazdaprtege
Jul 2, 2010 05:01 PM
madaz666
May 19, 2009 10:59 PM
imurfavbuddy
Feb 20, 2008 08:51 PM
