turbo for protege
Old Oct 24, 2006 | 04:07 AM
dx_protege's Avatar
Default turbo for protege
I have a '94 protege dx, it might not be a double but i got it for cheap, just wondering if i can get a stock turbo for it of a gt or something?
Old Mar 2, 2007 | 07:48 PM
fantomdave's Avatar
Default RE: turbo for protege
From what I understand the Mazdaspeed protege doesn't have any change in the compression ratio from stock. I am also not aware of any stronger parts being used. You would probably have to upgrade fuel injectors, pump, ect. The turbo on the speed proto only gives about 6 pounds of boost but takes the horsepower to 180. That is with the 2 liter engine and an intercooler but as long as you use a managable amount of boost I don't think you should have any major issues. Good luck.
Old Mar 3, 2007 | 01:12 AM
dr4g0n3's Avatar
no there is no known current applications for the 90-94 protege.
however you can do a engine swap either the BPTurbo with 180 horse
or the BPTurbo from the 323 GTR hatchback.
both engines come from the 323 hatchback however you need to get several things. a new flywheel. tranny, axels and engine mounts.
expect to pay $2400 - 3000 with whatever engine plus the parts if you want to look into it more. go to www.corksport.com. alot of great parts for mazda's
Old Mar 3, 2007 | 04:27 PM
wsoape281's Avatar
you need to rebuild your engine if it is that old before you turbo. all of the pistons and rods in the speed model are cold forged and dish-topped. also the head gasket is a lot more beefy on the speed.
wayne84
Jul 27, 2022 09:48 AM
xav6ier
Aug 11, 2015 10:11 AM
bluemazdaprtege
Jul 2, 2010 05:01 PM
madaz666
May 19, 2009 10:59 PM
imurfavbuddy
Feb 20, 2008 08:51 PM
