suspension
Old Mar 30, 2005 | 09:21 PM
momazda44's Avatar
Default suspension
Is it safe to put coil sping clamps on a mazda 3 to lower it 2 inches or will it mess with the alignment or anyhting?
Old Mar 31, 2005 | 10:33 AM
MAZDASERVICE's Avatar
Default RE: suspension
I WOULD NOT RECOMMEND TO DO THIS ...UNLESS YOU PURCHASE AND INSTALL A COIL OVER "KIT" WITH REPLACEMENT SHOCKS/STRUTS
IF YOU JUST PUT THE CLAMPS ON --YOU WILL DAMAGE THE FACTORY SHOCKS AND OR WEAR THEM PREMATURE.
ALSO IF THE VEHICLE IS STILL UNDER FACTORY WARRANTY IT MAY VOID THE SUSPENSION WARRANTY ON YOUR VEHICLE.
Old Mar 31, 2005 | 02:20 PM
Patrick's Avatar
Administrator
no,it is not safe, but neither are most of the other ways that some people lower cars nowadays...i have had a car with clamped springs, and i got NO WHERE NEAR 2" of drop...i got barely one inch...and it was a pain to do...the clamps work their way loose and rattle...its a pain.
Old Apr 11, 2005 | 11:07 PM
gforce's Avatar
it should be safe to install clamps, it will change your alignment some. may or maynot cause some tire wear issues. should look good
though with it lowered, wouldnt go over 2 inches.
Push2Drop
Sep 3, 2011 03:44 PM
Hobias
Apr 13, 2006 09:38 AM
Djshakes
Oct 3, 2005 06:30 PM
cvillareal
Aug 5, 2005 04:02 AM
millyman
May 2, 2005 09:39 PM
