Protege 99 key stuck in ignition...
Old Jul 10, 2011 | 03:39 PM
nade1's Avatar
Default Protege 99 key stuck in ignition...
Hi, My protege 99's key can't be removed from the car. I can start the engine, turn the engine off but it won't get under the ACC when i turn it counter-clockwise to get it out. The steering wheel won't lock at all when I turn it in both extremities. I unplugged the battery to see if it's an electronic problem but it still won't come out. I tried moving the cables under the steering wheel hoping that it would fix the issue, still no dice (i got that tip after googling all around). The car is standard (manual)
Can anybody help with this?
Thanks...
Old Aug 3, 2011 | 08:53 AM
tanprotege's Avatar
Do you push the key inward? There is a little spring that requires you to push the key inward so the key can't fall out by chance.
King276
Apr 6, 2021 10:17 PM
rk2976
Nov 28, 2017 11:14 AM
rgm2744
Jun 25, 2009 01:54 PM
DG
Mar 25, 2008 09:17 PM
soccermgr
Jul 13, 2006 02:06 PM
