2001 Protege misfiring
First thing I'd check for is a vacuum leak.
Assuming the tear is upstream of the throttle body, this cannot cause a lean condition as the MAF will still correctly identify the mass of the inbound air. More likely the leak (if one exists at all) is where the intake manifold for that cylinder meets the cylinder head.
The above said, AutoZone does maintain a "How-To" set of guides on their web site, complete with pictures. You might want to give that site a try.
In addition to a vacuum leak, since the code is specific to to the number two cylinder:
- Check to make sure that the plug wires are seated at both ends
- Make sure that the injector is working on #2 (use a screwdriver or similar as a stethoscope and listen for a click to indicate that the injector is pulsing)
- If the injector isn't working, check to make sure that the wiring harness is plugged into it
- Try running some Seafoam through it - does a good job of cleaning up carbon deposits
Unless an engine has been run on 1980s vintage Mexican gasoline, there should be no significant build-up of carbon deposits; even after a couple of hundred thousand miles. For the sake of argument, even if there were carbon deposits, they wouldn't cause a lean condition in one cylinder.
Just last year I bought a used car online. When I picked it up it exhibited symptoms of a car that needs a tune up. After I was comfortable that the there was nothing seriously wrong with the car, finished the deal and headed home. Driving on the hwy the engine still ran a little rough, so I stopped after ten miles and picked up some seafoam. I about half a can through the intake, covering the parking lot with a cloud of white exhaust smoke, and poured the rest into the full fuel tank. I then got back on the highway, dropping the trans out of overdrive and running the rpms up to 4000 or so for about two miles. The result was that the engine ran completely smooth for the rest of my 600 mile trip. It still needed a tune up, but burning the crap out of the cylinders/injectors really works.
