Protege 5 front end problem/noise
Old May 27, 2011 | 11:37 AM
brokenwing's Avatar
Default Protege 5 front end problem/noise
I have a 2002 mazda protege 5-manual trans, all wheel disc brakes, no ABS, 130K+ miles: There's this persistant/annoying problem with something in the front end. Seems like it's the right side. Shop did R bearing, rotors & alignment 4 mons ago. Was OK, but now noise is back. I swapped the R bearing again, the noise remained. So I swapped whole R knuckle and R tie rod end that seemed like it might be a bit sloppy... but I still have same noise (& very slight shimmy in steering wheel). The noise is louder as speed increases and the sound remains even if free wheeling/out of gear. (L knuckle was swapped 1 1/2 years ago, as well as both 1/2 shafts-CVs). I'm afraid to drive it over 55 mph, don't want to cause further damage. I jacked up front end, let wheels spin-they seem to turn true, no apparent bubbles on tires. Any ideas? What else can be wrong?...making me crazy! I love everthing else about this car-agile & fun to drive, but...!
Old May 27, 2011 | 03:25 PM
estranged575's Avatar
I have had similar problems for 8 months now. Had tie rod replaced 6 weeks ago, for the 3rd time, now making a "wub-wub" noise that will get louder, Anyone have any idea why this keeps happening after repeated tie rod replacements?
Old May 29, 2011 | 06:16 PM
kmesser123's Avatar
check into diffrential bearings and CV shafts, even if not torn the cv shafts can be bad, especially if you are on 130K OEM's
***NEVER*** lift a car and spin the wheels, the cv-shafts can fly apart from being at such an aggressive angle.
menash2
May 8, 2023 01:32 PM
racerxnico
Dec 2, 2013 07:36 AM
fflt765
May 25, 2012 12:52 PM
mickpdx
Jan 14, 2009 10:38 PM
dbaty
Feb 12, 2007 07:59 PM
