Po455 code-anything to look for? (EVAP LEAK)
Old Oct 31, 2010 | 06:16 PM
AllGoNoShow's Avatar
Default Po455 code-anything to look for? (EVAP LEAK)
1998 Mazda Protege with 1.8L, Manual Tranny. Car has thrown a PO455 code for a month or two now (Large EVAP Leak). I had a broken EGR tube and replaced that but apparently it was unrelated.
Anything common to look for on these cars as far as leaks? Gas cap looks fine. I don't even know where the charcoal canister is on these cars. If anyone can help me out it would be very much appreciated. Thanks.
Nick
Old Nov 4, 2010 | 07:01 PM
darkstar4100's Avatar
did you erase the code when you changed that hose?
Old Nov 6, 2010 | 06:55 PM
Yea I did, multiple times. In hindsight the EGR has nothing to do with the EVAP system so I'm not sure why I thought it was related. I did a visual test and everything looked ok (nothing obviously cracked)....Im gonna test the purge solenoid on the firewall and see if maybe it is stuck open. If it was actually a large leak in the line somewhere I figure I would have smelled it by now...but if the solenoid is stuck open it would just be leaking into the manifold. We shall see.
Nick
Old Nov 6, 2010 | 08:21 PM
Could be a bad fuel cap?
That's one of the most common, easiest to fix problem w/the evap system in modern cars.
Rayzcar
May 17, 2012 01:57 PM
intheblitz
Feb 27, 2010 04:05 AM
Bt5150
Mar 21, 2009 01:25 PM
protgurl
Jan 8, 2008 11:31 AM
mmich101
Jan 16, 2007 12:42 AM
