need some help
Old Aug 25, 2007 | 07:01 PM
stevechicago's Avatar
Default need some help
so i got a 03protege speed and i got a prob. see if i get on it alil bit and then when i let off
the rpms willjust drop andthe car will die... the check eng. light will come on and my bat. light but thats it not the oil light or anything just dies. also someties if i get on it it just wont go my foot will be on thefloor andthe turbo will turn u hear itbut it just wont go... anyone???? i was on someother forums and no one knew...im kinda on my last leg with this car to but i just like it to much to get somethng diff. but let me know
Old Aug 27, 2007 | 08:44 PM
hixx's Avatar
Default RE: need some help
Could be alot of things. The most likely possibilities i can think of offhand are restricted exhaust (bang on the bottom of the catilytic converter and see if it rattles like somethings loose inside)/dirty fuel filter/dirty throttlebody/dirty MAF hotwire/dirty injectors ( Techron works best for this/also decarbons the engine)/worn out coil and fuel pump. Just things to check. It's impossible to know without the car in front of me so you have to do the inspections and hopefully will learn a bit along the way.Run it by an Autozone and they can scan the PCM for codes free.
Old Aug 28, 2007 | 12:20 PM
cool thanks man i thought that it might have been the fuel pump but ill get that checked for sure thanks
Old Aug 28, 2007 | 12:36 PM
sonicshockwaves's Avatar
I have been having the same sort of issues with my speed protege, after quickly slowing down the engine will cut off, battery light come on, no check engine light comes on. I've replaced the Mass Airflow sensor, and O2 sensor, neither has helped.I was thinking something like a vaccum leak, bad idle control valve, or dirty egr valve.It's barely running, it will cut off just idling now, and all the places i've taken it to, including a mazdaspeed dealership can't tell me what's wrong.Please help before I lose my mind.
Old Aug 28, 2007 | 03:04 PM
hixx's Avatar
They do have a problem with carbon buildup in the EGR valve. Remove the EGR valve,disasemble and clean the carbon out of it.
Old Aug 30, 2007 | 05:05 PM
02protege's Avatar
seafoam the crap out of your car!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
the_gray_mazda6
Mar 3, 2016 09:47 PM
Alucard
Jan 14, 2006 01:34 AM
sweetncrazy_88
Dec 19, 2005 03:50 AM
Darkshot
Nov 4, 2005 07:05 PM
mymillenias
Oct 23, 2005 01:45 AM
