My battery will not stay charged please help 99 Mazda protege 1.8
Old Mar 29, 2022 | 02:54 AM
Nickmdnm2021's Avatar
Default My battery will not stay charged please help 99 Mazda protege 1.8
My protege will not keep my battery charged I think I have a draw somewhere and I can't figure out how to find the. Draw annd. Why my alternator is not charging my battery I have replaced both of. Them and it still isn't.chsrging please help is. There a way to diagnose where the problem lies and what's not working correctly
Old Mar 30, 2022 | 07:30 AM
What voltage do you have at the battery with the engine running?
Have you used a multimeter to measure current draw?
Old Mar 30, 2022 | 05:10 PM
It was 12.86 at the batter while running
Old Mar 31, 2022 | 08:59 PM
Grouch's Avatar
It should be 13.4 or higher when the engine is running. Your alternator isn't charging. I would pull it and have it bench tested. AutoZone and other parts stores will often do it for free. If you have a rebuilt unit, it's possible you got a bad one. I got three bad ones in a row from the same batch. A 4th one from a differenr rebuild batch worked fine. If you have a warranty, it won't cost you anything but time.
If the alternator tests good, you'll have to look for a bad wire or other reason. I tracked a problem down once where the negative cable looked fine where I could see. At the frame, under the engine, it was corroded nearly all the way through.
dsteh
Oct 13, 2021 11:39 AM
Hardakhar
Jun 22, 2015 12:04 PM
Evan Smith
Jul 15, 2013 08:04 AM
floater
Dec 11, 2010 09:35 AM
Jza
Nov 14, 2008 10:47 PM
