Headlamp Question
Old Nov 21, 2012 | 06:27 AM
Rockstar's Avatar
Default Headlamp Question
Hey all;
I've got a 2002 Mazda Protege5 and the driver's side lowbeam isn't working. The passenger side is fine. I've swapped the bulbs so I know it's not a bulb issue (tried new and the one from the passenger side). I've also checked fuses 20 & 21 & they're good. Also swapped between the two so I know the fuses are fine.
Anyone have any ideas on what else I can check? I took the car to a body shop to get the bumper painted and when I got it back the tail light (driver's side) was out - no problem, replaced that, all good but the driver's lowbeam won't come on.
All running lights, turn signals, hazards work fine.
Appreciate any suggestions!
Old Nov 21, 2012 | 08:55 AM
Which bumper, Front or Rear?. With front they would have probably had to remove the headlight assembly.
Old Nov 21, 2012 | 09:28 AM
tanprotege's Avatar
Everything is plastic around the bumpers so there should be a ground connection from the headlights to the steel body. It is likely included with the harness but I am not sure. Create a separate ground connection to see if the light goes on.
Use a volt meter to see if there is power to the light bulb harness.
Old Nov 22, 2012 | 06:32 AM
Rockstar's Avatar
Red face Ooops...
Thanks for the suggestions... UseYourNoggin is going to love this... LOL
Wrong bulb. Last night I had another look and actually used my noggin. It's when I placed a multimeter onto the sockets that it showed me I was looking in the wrong location and the wrong bulb.
Appreciate the help and the patience!
Cheers,
Old Nov 22, 2012 | 08:22 AM
Thumbs up
Cheers,
Awesome! That's why i picked that name on this Forum!
Sometimes we have bad days. A second look or thinking about it from a different perspective does help!
Attached Thumbnails Headlamp Question-homersimpsondoh.jpg   Headlamp Question-imagescahwb4mm.jpg   Headlamp Question-justsimple.jpg   Headlamp Question-savemoney.jpg
ballastrae
May 3, 2008 05:31 PM
Lev
Aug 23, 2007 04:27 PM
Lev
Jul 15, 2007 02:30 PM
MBS ROX
Aug 24, 2006 07:13 PM
RedRocket
Aug 25, 2005 09:48 PM
