Evap system help....P0455
Old Dec 6, 2007 | 07:06 PM
eddie jr's Avatar
Default Evap system help....P0455
Hey guys, new to this board, looks like a great place! I was just looking for a little help on the evap system. I have a 97 SE (Canadian) with 1.5L. I have the P0455 "large leak" code. I was doing some reading today and apparently the charcoal canister is under the car at the back! I thought that was weird as there is a black canister in the passenger corner of the engine bay against the firewall that i thought was the canister as it goes to the purge valve and then intake. Was it different on different models?
Has anyone had this issue before? Any typical problems? I figure check the lines under the car first.
thanks.[/align]
Old Dec 6, 2007 | 08:00 PM
MazdaES's Avatar
Default RE: Evap system help....P0455
My 1996 shop manual doesn't list that as a possible code. It is possible that is a canada only code Eh! I have seen many these EVAP system codes get cured by replacing the gascap.
Old Dec 6, 2007 | 10:14 PM
eddie jr's Avatar
hmmm, that's weird. I doubt it would be Canada only, iwonder if i wrote it down right....pretty sure i did as i have seen it in google searches too. What is your code for large leak in the evap system then?
gas cap seal looks in great shape.
Old Dec 9, 2007 | 08:20 PM
kcos20's Avatar
no you have the code right because i I have the exact one wrong with mine. I have an 02 protege lx and the check engine light came on a while back and said it was a small leak then recently came on again with the large leak. People tell me to check the hoses for a hole or something but you say it could just be the gas cap?
standard m6
Jul 2, 2023 04:17 PM
gertie508
Oct 4, 2015 08:24 AM
out of gas
Apr 28, 2011 06:12 PM
njhc
Sep 5, 2007 10:18 AM
