Engine squeal and loss of power
Old Nov 9, 2020 | 05:00 PM
Jametemp80's Avatar
Default Engine squeal and loss of power
For starters I have a 2001 protege with the 2.0.
So, I started noticing a slight engine squeal after driving for awhile. Car would start and run fine, with no engine noise. Then I would notice the engine would squeal with throttle. I thought it might be transmission, so I changed the fluid. No help.
Then the squeal started getting louder, and power started dropping. It was noticable when I started the car. Everything pointed at belts. So I disconnected the alternator belt, and ran the engine. Still a squeal. Did the power steering pump belt next. Still a squeal.
So I replaced the timing belt as it was over by 5k miles anyways. Guess what...still a squeal. I am at my wit's end with it. Any suggestions would be appreciated.
Old Dec 29, 2022 | 06:27 AM
02protegeDane's Avatar
Default Sorry to revive an old thread, did you figure it out?
I have this same thing happening to me on a new car I just bought and I’m worried it’s something serious
Old Dec 30, 2022 | 03:24 AM
Intake system air leak?
Low engine oil?
Low coolant level?
Old Dec 30, 2022 | 09:17 AM
Jametemp80's Avatar
Sorry I never posted the update. One thing I failed to mention was that the car had over 300K miles on it. I ended up placing the car on jack stands and had a buddy advance the throttle while I listened under the car. I eventually found the squeal was coming from the mani-verter. Once I removed the mani-verter, I saw that it was blocked almost solid. I made some modifications to it while I waited on a new one to come in from Rockauto. That fixed everything. The squeal was gone, power and economy picked back up. It was almost like it had a fresh engine in it.
Sonder
May 22, 2016 09:40 PM
ginman999
Dec 19, 2007 09:21 AM
anton1117
Nov 16, 2007 02:30 PM
dlheck
Nov 27, 2006 01:05 PM
portugee02
Mar 16, 2006 06:09 PM
