Rebuilt engine, lifted intake camshaft and broke
Old Feb 3, 2023 | 11:59 AM
Mp32001's Avatar
Default Rebuilt engine, lifted intake camshaft and broke
Its a 2.0L, 5 speed manual. We rebuilt the engine (new gaskets, bored it out, new pistons, rings, lifters) and its setup for a turbo, it ran amazing for a while I drove it about 100 miles on the rebuild then one day I did a pull in 3rd and the intake camshaft lifted on the side and broke. I assume its due to not tightening a bolt which would be my fault as I was the one who put the top end in. I'm just wondering the extent of the damage I've done? What all should I replace and am I gonna have to go through the pain of removing my engine again? Thanks for any advice!
Old Feb 3, 2023 | 03:35 PM
Yes there is something you missed that step. to do.It happens.
If you are lucky you should only need to replace the cam shaft and the *cam bearing (*if applicable) and maybe *cam caps? It is almost a common since question that if you think about it with your experience, anything that looked damaged should be replaced? What I would be the most concerned with if you spun a bearing and the material went through the engine?
Carey
Jun 21, 2011 12:51 AM
MakeShiftMazda
Mar 25, 2011 10:43 AM
fdqx
Oct 27, 2008 12:18 PM
mazda3power
Jan 23, 2007 03:46 PM
bassment_3
Jul 13, 2005 10:25 PM
