engine idle problems
Old Oct 4, 2005 | 12:52 AM
bhasting's Avatar
Default engine idle problems
Hello, I have a 2000 Protégé LX 1.6 - I have never had any problems with it, and it ran fine until recently when it started idling funny. Everything was fine while driving, but when you stopped the idle would drop low then come back up. I thought it was because the battery was going bad, but when I changed the battery it made it worst. I am not sure if it is a charging problem, sensor problem, or fuel system problem. Anyone had similar problems or heard of anything like this?
Also does anyone know where the fuel filter is located on this model?
Old Oct 4, 2005 | 10:57 PM
babyhuey's Avatar
Default RE: engine idle problems
Your plugs and air filter are ok? A check of the base idle speed would be a good first thing to check. One of the most common problems on this year with 1.6 engine was faulty Mass air flow sensors. Mazda has even extended the warranty on that part for 7 years or 70,000 miles as long as it is not a California emissions car. If none of these pan out then removing the Idle Air Control Valve to clean out might help as well.
Almost forgot. You do not have a replaceable fuel filter. The only filter is the pickup screen on the fuel pump inside the tank.
mazpro00
Jun 14, 2014 04:56 PM
bobotech
Dec 3, 2012 12:52 AM
lgibbons1
Mar 29, 2010 09:22 AM
xtrigger
Aug 10, 2006 07:02 PM
thakid22
Aug 26, 2005 05:16 PM
