Does anyone now how to remove the brake rotors and pads on a mazda protege 2000
Old Oct 30, 2013 | 10:45 AM
mazpro00's Avatar
Default Does anyone now how to remove the brake rotors and pads on a mazda protege 2000
Ive done them before on 96 ford taurus but i think they might be diffrent on this mazda
Old Oct 30, 2013 | 11:04 AM
tanprotege's Avatar
Mazpro: if you have done it on the Taurus you can do it on the Protégé.
Buy yourself the Haynes manual so you know the torque values and also read the sticky: The unofficial user's guide ...
Old Nov 23, 2013 | 09:15 PM
mazpro00's Avatar
does anyone know what what socket size i need to remove the caliper bracket off the brake pads it looks like some kinda torx
Old Nov 24, 2013 | 07:25 AM
mazpro00's Avatar
auctually from looking at the nut carefully it looks like a standard 12mm nut that can be turned with a socket or box end wrench not a torx
Old Nov 24, 2013 | 10:46 AM
N628PW's Avatar
I have a 2000 Protege ES.
If you're doing pads, you should only need to unfasten the bottom caliper bolt and slide the caliper upward to access the pads.
If you're doing pads and rotors you should be able to unbolt the caliper mounting brackets and take the whole assembly off. I think mine were 14mm although I'm not 100% sure.
Something I ran into myself when changing the pads; one side used a standard socket and the other side's caliper bolt had some allen/hex head and needed an allen wrench to remove. I believe that was 7-8mm. Could be something the previous owner did but just a heads up to check both sides before getting too deep into the job. You never know with an older car..
Old Nov 26, 2013 | 06:42 AM
mazpro00's Avatar
Finished the brake job yesterday changed both front brake pads and rotors there was no torx it was just two 14mm nuts on the caliper pins and 2 17mm nuts holding the caliper bracket. Very easy job.
Old Sep 7, 2014 | 10:45 AM
mazpro00's Avatar
hi guys once again doing a brake job due to my rotors wrapping i guess from when my cv axle leaking and the grease getting on the driver side rotor without noticing it for at least a couple of 2000 miles since the cv axle repair, i changed my rotors successfully greased caliper pins but my new brake pads seem to have a problem
pic attached
in the pic the middle hole in the inner brakes the hole has a different shape/ size then the others is this ok or should i get a replacement?
Old Sep 7, 2014 | 10:52 AM
mazpro00's Avatar
pic of brakes side to side
they are the gold wear ever ceramic brake pads from advance auto parts
Attached Thumbnails Does anyone now how  to remove the brake rotors and pads on a mazda protege 2000-08279cbacf6c47c3838f0b87e2ad27da_a.jpg
Old Sep 7, 2014 | 03:04 PM
mazpro00's Avatar
nevermind changed brake pads and thay are all the same shape now
ultrarevvin1
UltraRev
Jan 14, 2014 09:31 AM
mark5907
Nov 24, 2010 01:09 PM
JDiamond
May 6, 2010 05:32 AM
IBAUCLAPlaya
Apr 27, 2009 05:41 PM
doctor_joe87
Feb 15, 2009 08:59 PM
