Cat's fouled out- Just got a tune up need help!
Both Cats are melted. Had the front one replaced today, all ignition coils and plugs replaced. So I could clean the back one possibly? Guy said they were both bad. Already runs 10 times better after all that! I got a full tune up, air filter, plugs and wires and all that.
Unfortunately without actually testing the main rear or visually looking at it you won't know the condition it's in, but it does need attention ASAP.
Missfires Can Be Caused By a Million and One Things,
Vac Leaks
Wiring Issues
Spark Plugs(Even Fresh Spark Plugs That Are Crappy Quality.... E3 And Such)
Ignition Coils
Alternators (Search EMI)
MAFS
Injectors
Injector O-Rings
Intake Gaskets
TB Gaskets
PCV Hoses
PCV’s
Malfunctioning EGR
Malfunctioning CAS
O2 Sensors
Aftermarket Intakes
Intake Hoses
Vac Lines
Timing Chains
Timing Chain Tensioner
Broken Cam Gears
Malfunctioning Cam Sensors
Incorrect Crank Gears(The I4 Has Like 40 Different Configurations For Whatever Reason)
Incorrect PCM Flash
Issues Within The PCM
PCM Wiring
Bad Diaphram Within The FPR
Issues Within The Fuel Pump
Dirty Fuel Filter
Dirty Fuel Lines
Pre-Cats/Poor Exhaust Flow
I had a misfire, it was the poor exhaust flow, pre-cat causing it.
