1997 mazda protege surge/hesitation
Old Sep 11, 2015 | 08:35 AM
tanprotege's Avatar
Originally Posted by humoroustee
I had an impression that it was an ECU issue.
Yes it is , but not in the way you think. The ECU is doing its best to keep the engine running by compensating for faulty signals from the MAF and O2 sensors. Those signals are junk because there is a vacuum leak behind the MAF sensors. Hence the engine is running lean to various degrees.
Fix the vacuum leak. The ECU is just fine.
Old Apr 14, 2020 | 06:25 PM
Joseph187's Avatar
Default How do i change the fuel filter? Its hard to get to with any tools
Originally Posted by Brenden
Whenever i push on the throttle it surges or hesitates and it doesnt come out of it. if you hold the throttle down long enough with it surging the check engine light starts blinking. I recently did a clutch change on it and replaced the fuel filter and dumped some fuel treatment in it. what is causing this?
help me
MidAtlantian
Sep 6, 2010 03:59 PM
rgr1986
Oct 26, 2008 07:41 PM
gtyates
May 30, 2008 02:58 PM
johnnyone
Apr 9, 2008 06:58 PM
bjstoll
Jul 3, 2007 08:41 AM
