1996 mazda protege cam position sensor
Old May 20, 2014 | 09:40 PM
daquane25's Avatar
Hey I got the rotor to come off. I took it to school today and stuck it inside the vise and pulled up on it as hard as I could with vise grips. They ate the plastic up and I kept breaking pieces off and I finally popped it off with the best stainless steel butcher knife I have. I see that the screw that holds the shaft on won't come off. I tried using a 2.4 V electric drill, but I don't believe that's strong enough.
Old May 21, 2014 | 03:13 PM
tanprotege's Avatar
I am not sure which bolt you are referring to. I have a distributor in my garage and will look at it tonight.
Old May 21, 2014 | 03:19 PM
daquane25's Avatar
hey i got it off. it seems like i'm having bad luck. i see the part before ignition coil that has the transistor won't come off now..
Old May 21, 2014 | 06:19 PM
tanprotege's Avatar
I guess you did have some oil getting in there and it made everything stick. My tool of choice would be a manual impact driver, the type you tap with a hammer.
Old May 22, 2014 | 02:56 PM
daquane25's Avatar
Everything had oil on it. I got continuity when I checked everything. I cleaned it up and I will order the parts later on.
https://plus.google.com/u/0/photos/1...49148839884369
Old May 22, 2014 | 08:35 PM
tanprotege's Avatar
Wow!
Let us know how it goes when you have it back together.
Old May 23, 2014 | 11:22 PM
daquane25's Avatar
just wondering what would cause oil in a distributor and how could i fix it
Old May 24, 2014 | 03:53 AM
The oil leaks past old, worn, perished o-rings &/or seals.
Old May 24, 2014 | 09:30 AM
tanprotege's Avatar
All the pictures I have seen show only the large o-ring on the outside of the base. This one should keep oil form leaking to the outside. But there should be another seal on the shaft of the distributor which should keep the oil from getting to the inside of the distributor.
Old May 24, 2014 | 12:28 PM
daquane25's Avatar
so how would i get to the seal on the shaft
