1994 Mazda protege Transmission problems
Old Jul 13, 2008 | 09:46 PM
Mman09's Avatar
Default 1994 Mazda protege Transmission problems
i have a an 1994 mazda protege with an automatic transmission, but i am haveing problems with the transmission. When i put the car in drive and let of the brake the car goes no were it just sits there, and if you press the gas down it just revs. i think the ecu is senseing it is in neutral but i am not sure can anyone help me i need help asap i dont have a car now
-thanks Robert
Old Jul 18, 2008 | 04:05 PM
maggot666's Avatar
Default RE: 1994 Mazda protege Transmission problems
it might not be an ecu problem but a pressure problem in the transmission. What could be happening is there is no pressure building up in the transmission, so the pistons dont engageto driveyour input sun gear, and your output carrior is not being held. What you should do is have the transmission pump checked to see if it is at least moveing fluid. If that checks out fine then what you should check next is the friction and steel plates that hold and drive your planetary gears, they could be worn down so much that even with pressure applied to them from the piston they dont have enough material to grab on to.
ritolbc274qf
Jul 1, 2007 03:39 PM
bawest
Apr 24, 2007 10:31 PM
condor
Apr 15, 2006 03:02 AM
g_force
Nov 27, 2005 05:25 AM
cmamtm
Aug 24, 2005 02:30 AM
