clutch or trans
Old 08-07-2009, 11:32 PM
devin lantau's Avatar
Default clutch or trans
yesterday on my way home i lost all drive gears and revers as well is it the clutch or trans both ? could it be the rear gears or what im not sure what to take apart first????? thanks devin
Old 08-07-2009, 11:33 PM
thanks alot
Old 08-09-2009, 06:52 PM
mazdab2600's Avatar
not much info given=not much help.
yr/model/engine/manual/auto trans????
most have an inspection cover to check the clutch disk.
Old 08-10-2009, 02:39 AM
Kyrasis6's Avatar
If the clutch is bad you should still be able to shift when the truck is not running. If it is jammed in gear then the shifting forks are probably jammed up inside. It would require the tranny be removed and the tail housing taken off to get to the mechanism.
OziSpeed6
08-04-2013 11:27 AM
kayak-1
07-29-2013 06:36 PM
elcordovez
06-13-2010 12:52 AM
mazdaprotege97
12-24-2009 08:49 PM
millenia95
04-20-2007 04:13 AM
Quick Reply: clutch or trans
