1992 MX-6 running high and hot, now won't start...
ok, so my 1992 mx-6 was running fine until recently the temperature gauge started reading hot after about 5 mins of driving. Since I only use my car for commuting (about a 5 min commute) i was kinda letting it go (though i just bought a new thermostat thinking that it might help...didn't get a chance to install it though), when the car started taching (is that a word?) really high, no matter if I was idling or driving, the rpms were always around 2,500 unless i was shifting, i figured this was somehow related to the near-overheating and hoped that the thermostat change out would help, but then a couple day ago, before i could do the install, i went out to my car after work and it wouldn't start, i turn the key and it makes a momentary sound like it's going to start and then just dies with a slight clicking noise if i leave the key in the start position, it doesn't seem to be an electrical problem as the lights work and don't dim or anything, it just won't start....my thinking is that this is the starter and/or solenoid being shot...question is, do you all think that's correct? i'm trying to fix this myself and don't want to order a new starter if it could it be something else that i can't fix myself...and assuming it is, how hard is replacing the starter in one of these suckers?
thanks!
thanks!
Does the radiator fan kick on. I had a 91 and experienced similar problems. I ended up melting a radiator (plastic) before I realized the issue was a sensor that turned the fan on. If memory serves me, the mechanic that finally fixed it for me said there was a sensor that would not allow the motor to start if it was over heated.
Also, if you change the thermostat, I'd flush the system at the same time. Relatively cheap insurance. And if the thermostat mounts vertically, (I'm not sure on the 92's) make sure the little flappy thing is on the top.
little dutch
Apr 11, 2015 01:04 PM
cassey005
Jan 9, 2015 09:07 AM
kctech
Aug 14, 2007 10:26 PM
