MX-6 Quit and now won't start
Old Dec 11, 2008 | 08:53 PM
Army Dad's Avatar
Default MX-6 Quit and now won't start
While my son was home on leave from Iraq this fall, his1993 MX-6 diedin the middle of the road and wouldn't start.
When I arrived, I found that 1 of the plug wires had come off the bottom of the distributor. I assumed that was the problem. Connected the wire and it still wouldn't start.
Had it towed home and it has been in the garage since. He is due to backhome inFebruary and I would like to have it running when he gets here.
I replaced the Ignition Control Module. That wasn't the problem.
Could it have gotten out of time when the wire came loose and that is causing it not to start?
Possiblythe alternator?
Any and all help is appreciated.
Old Dec 11, 2008 | 10:44 PM
MJP68's Avatar
Default RE: MX-6 Quit and now won't start
what engine?? 2.0 or 2.5 manual or auto trans??
no spark correct??distributor failures were not uncommon for both engines.
be sure to pull the oil fill cap and have someone crank the engine over, watch the cams to make sure
they are turning, if so a distributor assy would be my best guess (make sure to stick with mazda oe parts)
if the cams arent turning, check the timing belt
Old Dec 12, 2008 | 05:06 AM
Army Dad's Avatar
This is a 2.5L V-6 with a manual tranny. You are correct on the no spark.
I will pull the cams this morning and post the results.
Old Dec 12, 2008 | 05:26 AM
Army Dad's Avatar
Part of my post didn't show up so I will try it again.
I will pull the oil fill cap and check the cams this morning, then post the results.
cassey005
Jan 9, 2015 09:07 AM
stencil
Aug 7, 2012 06:13 PM
dbraxton
May 15, 2008 01:35 PM
Hands on
Aug 7, 2007 02:32 AM
cugene
Apr 28, 2007 02:19 AM
