Replacing antifreeze in a 2004 MPV with rear heat/ac
Old Jun 1, 2007 | 10:06 PM
dagresh's Avatar
Default Replacing antifreeze in a 2004 MPV with rear heat/ac
What is the trick to replacing the antifreeze in a 2004 MPV with rear heat/ac. The capacity is a little over 3 gallons, yet when I drain the radiator, only about 1 - 1/2 gallons comes out. How do you go about getting a complete drain of the system?
Old Jun 4, 2007 | 02:43 PM
babyhuey's Avatar
Default RE: Replacing antifreeze in a 2004 MPV with rear heat/ac
You are not going to be able to drain out the full 12.7 quarts of the cooling system unless you pull the engine and roll it over a couple of times dagresh.You can however drain out a significant greater portion if you remove the plug located in the rear heater pipes under the vehicle approx mid vehicle. See somewhat weak diagram below for a better idea of the location.
[IMG]local://upfiles/1377/859FD08EFBFA44F3909992AC455DC24F.gif[/IMG]
deak
Apr 9, 2015 10:04 PM
Mazda-n-Me
Oct 29, 2012 01:04 AM
gucci
Jul 19, 2011 11:19 AM
thelordparadox
Aug 2, 2010 01:06 AM
tonto26
Apr 18, 2007 09:22 PM
