Replacing antifreeze in a 2004 MPV with rear heat/ac
What is the trick to replacing the antifreeze in a 2004 MPV with rear heat/ac. The capacity is a little over 3 gallons, yet when I drain the radiator, only about 1 - 1/2 gallons comes out. How do you go about getting a complete drain of the system?
RE: Replacing antifreeze in a 2004 MPV with rear heat/ac
You are not going to be able to drain out the full 12.7 quarts of the cooling system unless you pull the engine and roll it over a couple of times dagresh.:DYou can however drain out a significant greater portion if you remove the plug located in the rear heater pipes under the vehicle approx mid vehicle. See somewhat weak diagram below for a better idea of the location.
[IMG]local://upfiles/1377/859FD08EFBFA44F3909992AC455DC24F.gif[/IMG] |
