Head light switch/Relay
What year MPV do you have mazeyai? There has been quite a bit of problem with headlight switches becoming deformed under high heat conditions that would create the problem that you describe. Only lists for 94-97 but have seen on earlier model as well. Below is description of the TSB.
TSB: T007/98
HEAD LIGHTS COME ON AUTOMATICALLY
APPLICABLE MODELS
All 1994-97 MPVs with VINs beginning with JM3LV522V0819804 (2WD) and JM3LV523V0819807 (4WD).
DESCRIPTION
The light unit switch, located on the back of the combination switch, may become deformed due to high temperature exposure. This may allow the contacts to intermittently close, causing the headlights to come on automatically. Ribs have been added to the switch case and cam plate holder to reduce deformation of the switch case.
Symptoms are:
While the vehicle is parked, the headlights may come on although the switch is turned OFF.
When touching the combination switch to illuminate the turn signal, the headlights may come on.
The updated headlight switch is a Mazda Part #LB83-66-136 with MSRP of $55.05 US dollar.
TSB: T007/98
APPLICABLE MODELS
DESCRIPTION
Symptoms are:
BogusSVO
Feb 1, 2013 11:37 AM
mxteam
Oct 24, 2007 06:52 AM
supercrisp
Mar 27, 2007 10:08 PM
