Cruise Control Trouble
Old Apr 23, 2007 | 08:49 PM
zmanzke's Avatar
Default Cruise Control Trouble
My set/coast works- but the resume/accel doesn't. Why? easy fix?
Old Apr 23, 2007 | 09:12 PM
babyhuey's Avatar
Default RE: Cruise Control Trouble
Hi again zmanzke.
Problem has to be within the actuator switch itself which is part of the wiper lever assembly. Both functions use the exact same 5 volt input wire from the cruise control module as well as the same ground wire. The difference is just in the way the switch changes the 5 volt input by routing the voltage thru either a 910 ohm resistor for resume/accel or a 240 ohm resistor for set/coast.
Replacement of the wiper lever assembly is going to be your only way to get it all working right again. Wish I had cruise on my 323. Sure is handy on long drives.
Old Apr 27, 2007 | 01:38 AM
zmanzke's Avatar
Well, it is all working now. The fuel pump/sending units getting fixed next week, that was a bear finding one where I live.
jonjc
Jun 13, 2009 06:03 PM
loveindia
Jan 14, 2009 04:29 PM
brodrick
Jun 6, 2006 12:59 AM
Aaeen
Jun 4, 2006 01:55 PM
