2002 Mazda MPVcrank no start
Old Apr 16, 2019 | 11:41 AM
Amorrow37's Avatar
Im still not quite sure what you are saying. So ill just roll with it.
- If you changed several parts and now it wont start. Start by retracing your steps, check all connections and make sure they are fully connected.
- If you have tried starting your car a lot then your battery is probaly drained by now. It may need to be jumped or charged. (which could account for it sounding like it is struggling)
I will also tell you this. I recently changed my Cam Position Sensor on my Mazda 3. After the swap my car wouldnt start, It turned out that I had not push the plug all the way on to the sensor due to it having a tight fit. Once i pushed the plug all the way on it fired right up.
If none of this helps then please take your time to post a well thought out and written post the driscirbes everything you did and that is going on.
Old Apr 16, 2019 | 12:01 PM
Raquel Corchado's Avatar
Sorry I voiced text and didn't proof read it. You are right it struggles to turn on it just reves without out staying on.yes I went back and checked everything on this mini van I retraced and did it twice in case it didn't go through or if I messed up but I did everything correctly.this is what I was saying. I apologise for the confusion because I am work texting fast.
QUOTE=Amorrow37;174286]Im still not quite sure what you are saying. So ill just roll with it.
If none of this helps then please take your time to post a well thought out and written post the driscirbes everything you did and that is going on.[/QUOTE]
Old Apr 16, 2019 | 12:02 PM
I also have a brand new battery
Old Apr 16, 2019 | 12:18 PM
Amorrow37's Avatar
The Starter takes the most power from the battery. So even if it is new if you continusly try to start the vehicle it will drain your battery very quicly.
- Did you actually change the Cam position sensor or not? Your post says "tired". If so where did you get the replacment sensor from?
- Can you make a complete list of everything you did for the service.
Old Apr 16, 2019 | 02:16 PM
I changed spark plugs ,cam shaft position sensor, new battery , oil change ,and filter.
rickwschneider
Jan 15, 2016 11:05 AM
Belky Johnson
Aug 6, 2013 01:40 PM
bealer
Oct 10, 2012 06:50 PM
keithld50
Sep 28, 2011 09:50 AM
keithld50
Sep 27, 2011 11:45 PM
