02 rear brakes
Old Apr 11, 2007 | 01:55 PM
mholder24's Avatar
Default 02 rear brakes
[align=left]Hi, What is the correct process for pulling the rear drums on an '02 MPV?
thanks
Mike
[/align]
Old Apr 11, 2007 | 03:26 PM
mholder24's Avatar
Default RE: 02 rear brakes
[align=left]after looking through other posts again, it seems all I need to do is remove the two phillips screws and then pull the drum. It also appears the I can toss the screws since they were only there for assembly. Can someone please confirm ... thanks, Mike
[/align]
Old Apr 11, 2007 | 05:35 PM
babyhuey's Avatar
That would be correct Mike. Two #3 phillips screws per side. You will also notice a third threaded hole in the drum. If the drum is stuck on you can use one of the removed screws to thread into this hole to aid in getting the drum to break loose and come off.
Old Apr 12, 2007 | 12:16 AM
mholder24's Avatar
Thanks for the guidance ... I got a new tool and did the brakes on all for corners ... it was a good day.
Lee
Mar 23, 2007 09:55 PM
Euros
Mar 11, 2007 10:49 AM
Quer0zen
Aug 31, 2006 08:11 PM
jmy350z
May 22, 2006 10:17 PM
bkeogan
Apr 23, 2004 11:17 PM
