02 rear brakes
[align=left]Hi, What is the correct process for pulling the rear drums on an '02 MPV?
thanks Mike [/align] |
RE: 02 rear brakes
[align=left]after looking through other posts again, it seems all I need to do is remove the two phillips screws and then pull the drum. It also appears the I can toss the screws since they were only there for assembly. Can someone please confirm ... thanks, Mike
[/align] |
RE: 02 rear brakes
That would be correct Mike. Two #3 phillips screws per side. You will also notice a third threaded hole in the drum. If the drum is stuck on you can use one of the removed screws to thread into this hole to aid in getting the drum to break loose and come off.
RE: 02 rear brakes
Thanks for the guidance ... I got a new tool and did the brakes on all for corners ... it was a good day.
