tried everything to remove radio, help!!!
Old Jan 25, 2007 | 08:53 PM
mrsegal21's Avatar
Default tried everything to remove radio, help!!!
I need to remove the stock stereo to put in RCA adapters but i cant remove the unit. I tried every way i could think of using the U-shaped removal keys but couldnt make any progress. Does anybody out there have any ideas/insight? Please help!!!
Old Jan 25, 2007 | 10:23 PM
babyhuey's Avatar
Default RE: tried everything to remove radio, help!!!
What year millenia do you have mrsegal21? Guess does not really matter as they are al basically the same. You are using a total of 4 tools to remove the radio is in the diagram below. Make sure when inserting the tools that the ball tip ends are forced away from the radio as you are trying to engage the spring clips inside. Once all four are installed then spread the tools outward. There should be some spring tension in all four and pull straight out. Have run accross a few here and there where the clips were too badly bent outward to allow tools to engage though.
[IMG]local://upfiles/1377/2AD22342C2C2419CB21E65974791BAB0.gif[/IMG]
Old Jan 25, 2007 | 11:08 PM
mrsegal21's Avatar
It is a '96. I cursed my car for about 3 hours, wiggling those tools every direction i could concieve,got nowherebut crackeda little plastic edging. i wondered if there was maybe some vital step i wasnt aware of??
Old Jan 25, 2007 | 11:20 PM
keninn's Avatar
you have to get the din tools that have little ***** one the ends. when you insert each tool, you will feel/hear them snap into place. you then kinda pull the tools outward, and kinda jiggle the radio up and down, also pull outward slightly. sometimes it helps if you break one side free, then the other. once it comes out just a tad, you can pull it out easily. if you dont feel/hear the tools snap into place, then the clip(s) might be broke. i had this happen. i had to basically take apart the console, then reach in and compress the clips by hand. it is easy to take it apart, but there are several pieces involved.
Lindseykins
Apr 27, 2010 12:20 AM
Twodogz
Feb 17, 2010 02:10 PM
binky
Mar 24, 2008 06:36 PM
VB
Aug 3, 2007 08:51 PM
jordansportsfan
Feb 18, 2007 09:24 PM
