low beams not working - 95 millenia
Old Mar 17, 2007 | 02:23 PM
dgk996's Avatar
Default low beams not working - 95 millenia
[align=left]I have a 95 Millenia with 180k. The low beams do not work. The high beams do. I've checked the fuses and the bulbs.
Is one of the relays at fault? I have not been able to determine which relay could be the culprit because none are labelled 'lights'. I have searched the forum with no luck.
Thanks in advance!
[/align]
Old Mar 19, 2007 | 07:52 PM
babyhuey's Avatar
Default RE: low beams not working - 95 millenia
Could very well be a faulty headlight relay as the low beams are supplied power thru relay and high beams supplied power directly thru the headlight switch.
Headlight relay is located just to the rear of the underhood fuse and relay box. Wires colors as follows to help identify.
Two wires are Lightgreen w/ black stripe. These two are power into the relay from 40Amp HEAD fuse.
White wire is power out to the low beams bulbs.
Black w/ red stripe goes to the headlight switch and should get continuity to ground with low beams turned on.
kenp005
Apr 25, 2022 12:11 AM
CanAva
Jun 9, 2019 07:35 AM
emc1220
Feb 19, 2008 08:36 PM
parkmazdajon
Mar 19, 2007 07:40 PM
dulcetcalamity
Jan 19, 2007 11:50 AM
