A/C compressor clutch
Old Nov 15, 2007 | 09:03 PM
wilburn's Avatar
Default A/C compressor clutch
My 1995 Millenia 2.5 (not "S") has a A/C problem. The clutch will not engage. I checked all A/C fuses. All are good. I unplugged hot wire from clutch and wired directly to battery. It worked fine. The compressor is not frozen. It turns freely when the clutch is engaged. Is there a relay that may cause this? If so, where is it? My owner's manual does not identify the relays. Any ideas??? Thanks!!
Old Nov 16, 2007 | 02:59 PM
jloncp's Avatar
Default RE: A/C compressor clutch
If your ac system has a low charge it won't engage the
clutch. I would start there first. I'm not sure were your relays
are but it does have a relay that runs your compressor.A bad ac pressure sensor,or a evaporator temp sensor can cause this problem **they control your relay**
Jloncp
Old Nov 16, 2007 | 03:20 PM
wilburn's Avatar
I bypassed the pressure sensor and it still does not work. I do not know where the evaporator temp sensor is located. Can you tell me where it is located and what it looks like?
Old Nov 17, 2007 | 06:01 PM
jloncp's Avatar
It is a probe with a couple wires that is inserted in the evaporator coil,if the coil gets to cold/freeze condition it shuts the compressor off. I have a
96 dodge intrepid that I changed out,it had a little access panel on the air duct under the passenger side dash. I don't know about your 95 millenia.
Hope this helps.
Old Nov 17, 2007 | 06:58 PM
wilburn's Avatar
Thanks!! I'll try to find it.
OziSpeed6
Aug 4, 2013 11:27 AM
kayak-1
Jul 29, 2013 06:36 PM
faris
Feb 22, 2013 03:53 PM
mazdaprotege97
Dec 24, 2009 08:49 PM
depfer1
Jun 2, 2006 05:12 PM
