99 Milly 64K
Old 02-15-2010, 04:02 PM
Ebaker2010's Avatar
Default 99 Milly 64K
i have recently pruchesed a 99 milly 2.3L supercharged with 64K on it. im having some issues, i currently drive a 98 camry 4 cylinder and right now the camry is faster then the milly. the milly blows WHITE smoke all the time and has noooo power at all. if you ease in to the throttle it is a little bit better. there is no coolant loss that i can find. i seem to think that is the supercharger, does coolant run through the supercharger???? what should i do to dio it? can i hook up a boost gauge to the supercharger to see out put??? any insight would be great! thanks alot
Evan Baker
Old 02-17-2010, 09:05 PM
keninn's Avatar
the compressor is probably dead. and, driving it like that, you probably have killed the pre cats. so, reman compressor, about 2 grand. precats, another 600. parts and labor, probably another grand. then you probably got bad motor mounts, axles, plugs, tees, and some others that will pop up soon. not such a good deal after all.
Old 02-17-2010, 09:59 PM
Ebaker2010's Avatar
Default just bought it
i just bought it and there is no check eng light with no codes or history, and it the light doesnt flash. how would that kill the pre cats? too much fuel or to little?? would you try just the compressor first b4 cats??? wont do any more damage will it? thanks for all you input
Evan
Old 02-18-2010, 09:58 PM
keninn's Avatar
a bad compressor wont throw a code. a bad compressor WILL make the car run rich. that will kill the precats fast. a simple boost gauge will immediatly tell you if the compressor is bad. they are not fun to change. but, compared to the pre cats, you will like changing the compressor. i'd suggest pulling the plugs to see if they are fouled, but pulling the plugs is not a fun job, either. more fun than pulling the compressor, tho.
Old 02-19-2010, 02:43 PM
Ebaker2010's Avatar
Default 99 milly
where can i hook up the boost gauge to??? is the vaccum line easy to get to?? thanks alot for all you input.
Evan Baker
Old 02-19-2010, 07:24 PM
keninn's Avatar
Evan Baker
is this a trick question? cause there's about 21 FEET of vacuum line on a 2.3. i would connect it to the dashpot on the abv. which is the gold colored thingy under the cover that says miller cycle. right about where the cycle is. or, tee into the map sensor. which lives on a bracket right behind the passenger upper strut mount. actually, thats probably a better source, but it could interfere with the map sensor if you leave it on. but then, you knew that, right?
Old 02-20-2010, 06:03 PM
Ebaker2010's Avatar
Default 99 milly
i didnt know if there was a specific port on the supercharget to tap in to. so the easiest place would the the map sensor makes sense manifold absolut pressure. durr thanks alot for all you help! ill let u know when i deciede to work on it.....
$96mill
04-12-2006 12:01 AM
cuyuni
03-09-2006 03:51 PM
itejeda
03-08-2006 01:03 AM
old929guy
10-13-2005 01:13 AM
BlackMillyS
08-19-2005 09:49 AM
Quick Reply: 99 Milly 64K
