Water leak when it rains, under pass. seat
Old 12-29-2006, 03:11 PM
Richard's Avatar
Default Water leak when it rains, under pass. seat
RE: water leak pools under passenger seat - 12/29/2006 12:59:54 PM
showPicture("12/29/2006 12:59:54 PM",0,0,0,638,9)
Richard
titleAndStar(6,0,0,false,",")
New Member
[align=center][/align]
Status: online
My 97 Millenia has the same problem, it is like water is running down insidethe B pillar and flooding under the passenger seat and rear seat carpet, same side. Only when it rains. Anybody have ideas? Thank's to all,
Richard. [align=right]
[/align]
Old 12-29-2006, 11:25 PM
keninn's Avatar
Default RE: Water leak when it rains, under pass. seat
i would suspect the door membrane. if anyone has removed the door panel, and not properly replaced the membrane, it will leak. stereo speakers, window lifters, if any of those have been replaced, they did a sloppy job.
Old 12-30-2006, 11:44 PM
Richard's Avatar
I will check that, I should have also mentioned thatI getwater on the right side of the passenger seat, about 3 inches from the right side. I thought it might be coming in from the bolts that hold the grab handle I popped up the plastic trim on the roof and sprayed plastic conformal coating (several coats) that we use in the avionics to keep moisture from getting to circuit boards and components. It looks like It is coming from the sun roof, do the drain holes and tubing run down the B pillar and how would I unclog them? Happy New Year to All
Richard.
Old 01-18-2007, 12:40 AM
Richard's Avatar
It was the drain holes on the pass side of the sunroof.
Old 05-04-2021, 08:41 PM
Shlymc's Avatar
Default Water solution
How did you figure out it was the drain holes and how did you unclog them?
dgonsoulin
01-20-2020 09:34 PM
Jaom
07-30-2012 04:45 PM
oatis314
04-19-2008 07:34 AM
austintitus3
12-29-2006 02:59 PM
mazda69
06-02-2006 05:26 PM
Quick Reply: Water leak when it rains, under pass. seat
