99 Millenia S misfire
Old Oct 13, 2012 | 09:01 AM
TEH's Avatar
TEH
Thanks for all of the insightful analysis. I will check it out.
Old Oct 22, 2012 | 09:39 PM
triomillenia's Avatar
Keninn, very interesting what you have experienced with cats going bad. Have you ever measured exhaust back pressure? Maybe this would be a good test to tell the condition of a cat. I have the tools to do it, but haven't had the time to experiment much with my Milly.
Anyways, I would check compression and do a leak down. Low compression, but a decent leak down would indicate a timing problem. I searched for the cause of a random/mulitiple cylinder misfire for months to find that a cam bearing had gaulled and the timing sprocked had twisted slightly on the cam. This thru my timing off even though all my timing marks on the pulleys lined up.
Old Oct 23, 2012 | 07:48 AM
Here is a general video on how to check if cat is bad.
Old Oct 23, 2012 | 10:07 PM
Good video. Looks like on his gauge anything higher than 5 psi pressure differential across the Cat was considered bad. If you have 5 psi of pressure anywhere in your exhaust AT IDLE, your in bad shape. I have one of these pressure gauges. I have only used it once, to do some testing on an 87 Supra. I had what I guessed to be excessive exhaust pressure at higher rpms. I measured both pre and post cat and graphed it versus rpm. I had a cheap OEM exhaust and muffler from Autozone. I made my own cat back exhaust with a Dynomax muffler and considerably dropped my pressure at high rpms. The power increase at high revs was easily noticeable.
When I get the time I will record this data for a milly also.
hilarie19
Feb 11, 2015 10:20 PM
ocnats milly s
Mar 23, 2012 08:18 AM
scarr91
Jul 21, 2010 03:55 PM
MazdaJohn987
Jan 24, 2009 11:04 AM
CardsFan420
Nov 8, 2006 06:25 PM
