95 millenia dash clock/a/c LED
Old Jan 5, 2009 | 07:34 PM
wilburn's Avatar
Default 95 millenia dash clock/a/c LED
My 95 millenia suddenly quit displaying the A/Cand heatertempand clock. I checked fuses that apply and found none bad. The A/C and heater still work fine. I just have no read out. Is there a bulb behind the display? If so, how do I replace it? Does the plastic lens in front of the display pop out? All the rest of the dash lights and displays work fine. Can anyone help????
Old Jan 14, 2009 | 10:38 AM
keninn's Avatar
Default RE: 95 millenia dash clock/a/c LED
ORIGINAL: wilburn
it's a separate display, and easy to change. get one off ebay, probably 20 bucks. it is amazingly huge. actually, i recommend you look for the entire assembly, with the cc amp, too. they are usually on ebay, and should be about 50 bucks for the complete assembly. you have to pull that part of the dash off, and it attaches from the inside. easy to do.
Old Jan 14, 2009 | 07:57 PM
mrmoneyman's Avatar
I just brought a AC Display online and im having trouble replacing it with the old one... Could anyone tell me Where are the screws located and how many are they? I tryed today but it seems like somethinng is still holding the dash in... maybe im missing some screws
Old Jan 15, 2009 | 08:05 AM
keninn's Avatar
on each side of the steering wheel, you will see a rectangular cover. underneath is a screw. take these off, then the entire assembly pops off. i open the glovebox, and gently pry from there. the assembly comes off just enough to disconnect the harness's.
Old Jan 15, 2009 | 01:24 PM
mrmoneyman's Avatar
Is there a screw under the dim light control? Im having trouble removing that cover...
Old Jan 20, 2009 | 05:35 PM
mrmoneyman's Avatar
Anyone know?.....
Old Jan 21, 2009 | 11:38 AM
keninn's Avatar
ORIGINAL: mrmoneyman
Anyone know?.....
yup. it's under there, and that control is kinda tricky to pull, which you have to to get it out
northurm
Dec 17, 2010 08:47 AM
Koolbreeze
Apr 12, 2009 12:55 PM
michael91077
Mar 25, 2008 11:02 PM
import_fan7
Jan 3, 2008 10:36 PM
rx4to6
Jan 17, 2006 06:53 PM
