Miata custom axle question
Old Oct 31, 2006 | 10:07 PM
Thumperman's Avatar
Default Miata custom axle question
I have built a rotary powered Triumph Spitfire autocross car, using a 2nd generation RX7 differential and 1st gen (1.6) Miata rear suspension uprights. I had to build my own custom axles by splicing RX7 inner CVs and 1.6 Miata outer CVs with a welded together shaft due to the different spline diameters and have snapped one in two for the second time.
My question is two fold:
1) Can the 1.8 Miata rear wheel bearings and hubs be used in 1.6 car rear uprights, or will I need to swap everything? This would, as I understand it, give me the large spline CVs on both ends of the shafts. I'd like to keep the 1.6 brakes for clearance reasons.
2) Who out there machines custom CV axle shafts? I need them machined from a solid steel piece, there's not enough clearance for a tube shaft.
Thanks in advance.
rynoracer32
Apr 22, 2013 04:55 PM
faint26
Oct 1, 2008 06:33 PM
milsco
Jul 13, 2007 05:22 PM
mk2guy
Apr 4, 2007 12:42 AM
rx7champ
Nov 25, 2005 07:17 PM
