engine swap
Old Mar 13, 2006 | 08:32 PM
speedshifter326's Avatar
Default engine swap
hi, im new here. Im am looking to put a V6 in my miata. Does anyone know of an engine that would drop in without too much modification? I had the toyota 4 runner engine in mind. thanks
Old Mar 27, 2006 | 07:43 PM
87 turbo II's Avatar
Default RE: engine swap
people have put 5.7L LS1 engines from Corvettes(C5s). I'm sure you can do it, how much modification is needed I don't know, but it shouldn't give you too much trouble. Good luck with that.
Old Mar 27, 2006 | 09:56 PM
MikeMzda3's Avatar
keep the engine, rebuild it and get a turbo = )
its a ton easier and the power to weight ratio will be insane - plus you could always get a bigger turbo later on.
Old Mar 27, 2006 | 11:50 PM
yeah I agree with that ^^^^^ but you asked if the V6 would go into it smoothly. I gave you my answer. Now if you want an opinion, get the new 170 hp Mx-5 engine and N/A tune it up. you'l have fast response and can make probably around 220 hp wihtout going force fed. That way you maintain your 50/50 weight too turbos weigh alot.
Old Mar 28, 2006 | 12:57 AM
MikeMzda3's Avatar
haha i was just puttin in my 2 cents...i like your approach tho...those new miatas are sick.
Old Mar 28, 2006 | 10:57 PM
Sunday I saw a 3rd Gen Limited at a Mazda meet. It was #240 of 3500 made. Special color ("Velocity Red" as apposed to miatas "True Red", it's practically the same but the Velocity is a little brighter and has red metallic flake in it) option package, accenting, badging, and I think exhaust as well. It was awesome. Now I won't like them unless it's limited.
Old Mar 28, 2006 | 11:55 PM
Tracker's Avatar
engine swaps can be hard to do if you dont what your doing, my suggestion is to do what 87 turbo II said, as for aftermarket that make good parts for engine rebuild their are too many good ones to choose from, but as for the turbo if you decide to even do all of this id suggest turbonetics.
KBJ!MP5
Apr 7, 2015 01:22 PM
fobmasteralex
Jul 20, 2009 01:46 PM
natepimp
Sep 13, 2007 10:32 PM
sicsidrx7
Jan 22, 2006 10:19 PM
justyn
Jun 25, 2004 06:21 PM
