Rubber tip on door handle fell off
Old Dec 28, 2019 | 06:34 PM
Daves590's Avatar
Default Rubber tip on door handle fell off
Hello members,
I hope someone can help me with this...
I own a 2012 CX9 Grand Touring.
The rubber tip on the door handle that is used to lock and unlock the car fell off and is nowhere to be found.
The dealer wants around $400 to "fix" it, saying that the rubber piece does not come on it's on and the whole handle needs to be replaced which requires 2 Hours of Labor + the cost of the new door handle!
This seams very excesive to me.
Did anyone else had this problem and is there any other solution?
Your wisdom is much appreciated.
Old Dec 30, 2019 | 04:56 AM
No you can't replace it on its own.
Labour would be maximum of 1 hr.
Have you priced up a 2nd hand handle from the wreckers? Ebay? Amazon?
Old Dec 31, 2019 | 08:10 AM
Mathew KOan's Avatar
Default Can you show me a picture?
I have the same vehicle, I am not sure what rubber piece you are talking about. I would like to help if I could but could you upload a picture of the passenger side showing the rubber piece and the driver side showing the same piece missing?
thank you
Old Dec 31, 2019 | 11:02 AM
Daves590's Avatar
Old Jan 4, 2020 | 05:45 AM
Daves590, have a look at this.
https://www.ebay.com.au/itm/2x-Door-...0AAOSwHblduXMK
Old Jan 5, 2020 | 03:24 PM
Daves590's Avatar
This looks perfect, except they don’t ship to the US...
Thank you though, I will see if I can ship it to a friend in Europe who can mail it to me later.
Old Jan 6, 2020 | 03:31 AM
Maybe try searching ebay USA for the same part description.
https://www.ebay.com/sch/i.html?_fro...+CX-9&_sacat=0
Old Jan 25, 2020 | 03:21 PM
LordEntrails's Avatar
This happened to my CX-9. Fortunately I still had/found the small plastic piece that goes inside. But if you have lost yours you can find a small (roughly 1.5x2x3mm) piece of plastic, place that in and make sure you can push in and trigger the door lock. It should just barely stick out of the hole (so it is just a little proud of being flush). Then use a black mouldable glue like this "Sugru Moaldable Glue" to form a small cap/button. Mine has lasted about 3 months so far and is doing well. It looks like OEM unless you look really closely (though I spent some time getting it to look right).
01Trib
Aug 20, 2022 03:09 PM
Erich Zimmerman
Jan 24, 2017 08:04 AM
Da Maz
Jan 7, 2015 06:57 PM
Phreak66
Jul 2, 2009 09:06 AM
DaveDanger1214
Oct 24, 2007 09:39 AM
