No Ac or heat through the vents
Old Dec 2, 2020 | 08:44 AM
Blan240's Avatar
Default No Ac or heat through the vents
I have a 2010 CX-9. The ac was working but it took a while for the blower to kick on. Now it’s cold and the heat won’t come on at all. Where do I start?
Old Dec 2, 2020 | 12:14 PM
PTguy's Avatar
Is the blower working? Does it blow air, just not heated or cooled air?
If the blower is working, the dampers in the system that open or close to direct the air flow (floor, defroster, etc.) may be defective.
If the blower is working and you can use the controls to change from floor air to defrost air to dashboard air flow, is the car's cooling system in good order? Coolant up to the correct level? Engine warming normally?
Old Dec 7, 2020 | 11:32 AM
Blan240's Avatar
Default Does it blow air, just not heated or cooled air? The blower works sometimes for heat
If the blower is working and you can use the controls to change from floor air to defrost air to dashboard air flow, is the car's cooling system in good order? Coolant up to the correct level? Engine warming normally?[/QUOTE]
ESMAZDA
Nov 17, 2020 10:19 AM
Mcjorcol
Aug 26, 2020 09:18 AM
jwehrheim
Aug 12, 2020 10:47 PM
El Jefe 951
Aug 29, 2013 04:33 PM
3333frank
Mar 29, 2013 10:10 AM
