CX9 won’t crank
Old Feb 28, 2023 | 08:50 AM
dad004's Avatar
Default CX9 won’t crank
What is this?
Old Feb 28, 2023 | 08:54 AM
dad004's Avatar
Yesterday I went to start the car, but it wouldn't crank. I don't think it's the battery(headlights appear normal). I watched some video's on Youtube and some suggested fuses and the starter. But then I noticed this hose was disconnected. I connected it, but the car still won't crank. Any ideas on what might might be at play? Was that hose the initial cause, and lead to other issues?
Old Feb 28, 2023 | 09:23 AM
dad004's Avatar
I connected that hose, and also hit the starter a few times with the tire iron. The car started. Did that hose have anything to do with it starting, or was that mostly me hitting the starter?
If it is the starter, is it a big job to change it? I haven't found any video's for it.
Old Mar 1, 2023 | 05:42 AM
That hose would have to effect on the engine not cranking.
Sounds like you need a new starter motor.
Old Mar 1, 2023 | 09:05 AM
Welcome to the forum.
Load test battery.
Check voltage at starter while assistant actuates starter button.
If battery load test good and voltage to starter, then remove starter and bench test or just replace it.
Old Mar 3, 2023 | 12:28 PM
dad004's Avatar
Does anyone know of where I can find a video to replace the starter on a 2012 CX9?
Matthew1
Jul 25, 2020 03:28 PM
Tomcatt
Jul 11, 2020 07:56 AM
Melgar101
Jan 26, 2017 09:38 AM
Redeemer
Mar 28, 2013 04:19 PM
isaac2484
Oct 4, 2009 05:03 AM
