Bluetooth setup voice recognition and training
Old Aug 22, 2007 | 05:53 PM
jimschott's Avatar
Default Bluetooth setup voice recognition and training
The CX-9 Bluetooth setup procedure refers to the car's manual for setup, learning/training phrases. I did not find this in the car's manual but support@mazdahandsfree.com (1 800 430-0153) forwarded the Bluetooth manual. Here's an excerpt:
Voice recognition learning function (Speaker enrollment)
The voice recognition learning function enables voice recognition appropriate to the characteristics of the user's voice. If the recognition of the voice input commands to the system is not adequate, this function can largely improve the system's voice recognition of the user. If your voice can be recognized sufficiently without using this function, you may not realize the added benefit of the function, as high-level voice recognition can be achieved by using this function. To register your voice, the voice input command list must be read out. Read out the list when the vehicle is parked. Perform the registration in as quite a place as possible (page 6050103(Voice) . The registration must be performed completely. The required time is about 10 to 15 minutes. The user needs to be seated in the driver's seat with the voice input command list for voice recognition learning open to the page indicated below.
[ol][*]Press the phone button (Short press).[*]Say: [Beep] "Voice training" [*]Prompt: "This operation must be performed in a quiet environment while the vehicle is stopped. See the owner's manual for the list of required training phrases. Press and release the phone button when you are ready to begin. Press and hold the phone button to cancel at any time."[*]Press the phone button (Short press).[*]The voice guidance reads out the voice input command (refer to the voice input command list for voice recognition learning). (Ex. "Please read phrase 1")[*]Say: [Beep] "#790" (Say the voice input command for voice recognition learning (1 to 45) according to the voice guidance.)[*]Prompt: "Speaker enrollment is complete, returning to main menu." [/ol]
Voice input command list for voice recognition learning When reading out, the following points must be observed:
Read out the numbers one ala time correctly and naturally.
(For example, "1234" must be read out "one, two, three, four", not "twelve, thirty four".)
[ol][ul][*]"#'Must be read out "Pound".
[*]"*'Must be read out "Star".[*]Do not read out parentheses. " (" and hyphens "-" are used for separating numbers in a phone number. Ex. " (888) 555-1212" must be called out "Eight, eight, eight, five, five, five, one, two, one, two."[/ul][/ol]
Command List
1#790
2*671
3212-4903
4235-3494
5315-5657
6456-7930
7793-5462
8794-1826
9826-3145
10962-7305
11(531) 742-9860
12(632) 807-4591
13(800) 222-5015
14(888) 555-1212
15123456789
165566778899
174433221100
18Call 293-5804
19Call *350
20Call (234) 567-8901
21Dial 639-1542
22Dial #780
23Dial (987) 654-3210
241058# 3794# Send
2527643# 4321# Send
26Cancel
27Continue
28Emergency
29Erase All
30Help
31Home, Work, Mobile, Pager
32List Names
33No
34Phonebook: Delete
35Phonebook: New Entry
36Previous
37Phonebook: Erase All
38Redial
39Retrain
40Setup Confirmation Prompts
41Setup Language
42Setup Pairing Options
43Pair A Phone
44Transfer Call
45Yes
Old Nov 15, 2015 | 11:20 PM
skidog's Avatar
Hi, Im having the hardest time finding what screen I need to be on for Voice learning or Voice Setup. I have all the above instructions but do not and can not figure out what screen I must be on. Thank you for your help.
ThankYouMazda
Jul 14, 2014 06:18 PM
ogcsmith
May 5, 2013 03:47 PM
Simo1122
May 10, 2009 11:06 PM
hcw427
Apr 16, 2009 01:01 PM
mayor4
Sep 15, 2007 11:32 AM
