AWD conversion
Old 07-18-2017, 09:27 PM
iggyfan's Avatar
Default AWD conversion
Hi this is my first post as I'm a new member. I'm kind of new to Mazda being a lifetime Honda owner I bought a used 2010 CX-9 AWD touring which I knew needed a new trans and transfer case due to the output shaft from the trans to PTU being stripped. I am a mechanic by profession for over 25 years but mainly Honda and GM vehicles. My question is I want to replace the trans with a FWD trans and eliminate the AWD components. I figure I will replace the right front axle and install the carrier axle and bracket since the PTU won't be there and I'll probably remove the rear driveshaft too. Another reason why I want to do this is cost AWD trans is 3000.00 for reman and 900 for PTU and the final reason is I can't seem to communicate with the AWD module with my scanner. So has anyone heard if this is possible or tried and succeeded doing it? I have done this for a few customer GM vehicles which had severe problems with rear differentials etc and have had no issues there. As far as I can tell the transmissions appear to be very similar between AWD and FWD.
Thanks for any help on this matter
colin22
06-12-2008 03:18 PM
fuedaddy
12-13-2007 02:20 PM
Tracker
01-31-2007 08:38 PM
azlan609
09-14-2006 01:13 AM
falcon2691
02-11-2006 08:04 PM
Quick Reply: AWD conversion
