2015 CX-9 remote start in the cold morning, shuts off after few seconds
Hello all! Long-time lurker here because we don't get much problems with our 2015 CX-9, except for now...
My family lives in the extremely cold Midwest. We get to sing digit negative temperatures in the mornings here... which may be connected to our problem.
The CX-9 is my wife's. I am the designated person to warm it up in the mornings because I leave the earliest. The remote start was working until about some day last week. When I press on the remote start, it only runs for a few seconds. So, I have to go out to start it manually and rev the accelerator a little, then I leave it to warm up. After about 10 minutes, I turn it off. My wife is successful to turn it on remotely when she leaves to work about 30 minutes after ot was shut off from my warming up. I have just just changthe battery a few hours ago. But when I tried to remote start, it still shut down after a few seconds.
Any advice?
Thanks!
Any advice?
Thanks!
When you said "it only runs for a few seconds", did you mean the engine actually fires and idles for a few seconds before cutting out and not attempting to start and just giving up?
When the engine cuts out, do the gauges on the instrument cluster stay lit - as though ONLY the engine died - or is everything turned off as it would be if you manually turned the engine off?
Just to test and hopefully isolate the culprit, avoid remote starting and instead manually start it for a few mornings and see how it behaves.
Not really sure what to make of it. If completely bypassing the remote start in the morning eliminates the problem, then it's seems that feature is what causes the engine to die within seconds. And since you said the instrument cluster stays lit after the engine dies, it seems only ignition is cut off because restarting it fires up the engine right away - so it's not the fuel.
You did not mention if the remote start on your CX-9 is OEM or aftermarket. A dealership or reputable shop may be your best option to properly diagnose/fix the problem, unless someone else here offers a solution.
GM991
Mar 25, 2008 08:42 AM
