No power when accelerating
Old Aug 31, 2022 | 05:21 AM
Emmswala's Avatar
Default No power when accelerating
I recently had my timing chain replaced and then they said my camshaft needed to be replaced as well because there was oil leaking I now have no power when I put my foot down to Excelerator my car was driving fine before then the mechanic doesn’t know what to do because someone please help me it’s reading code P0012 any help would be much appreciated
Old Sep 6, 2022 | 09:54 AM
tnt4him's Avatar
without a doubt your mechanic screwed up on the installation. Mazda supposedly meant to make the timing chain install fool proof using friction washers and a special tool for alignment. But there are ways to mess it up. This engine does not use notched keys on the cam or crankshaft gears. this is a huge difference between other normal cars/ engines. They can move in the install process and there goes your timing. Pain to do all over again. The camshaft does not leak all by itselt but the seal on the right side might leak. Replace the seal would stop the leak. Just replacing the camshaft itsellf would not stop the leak. You have to go back and simply tell the guy the timing is off and it doesnt run right. show im the code. Be sure to ask if they used new friction washers and bolts. Using the old ones may cause it to slip.
23ltMazdaDriver
Oct 9, 2021 04:47 AM
stecarr
Dec 20, 2019 07:59 AM
Thiss
Jun 15, 2019 02:47 PM
Jnine13
Feb 17, 2017 03:28 PM
wikdwelder
Apr 22, 2007 02:36 PM
