Mazda CX-7 2006 Turbo and Rear Main seal.
Old Jan 6, 2025 | 09:24 PM
Mumma0079's Avatar
Default Mazda CX-7 2006 Turbo and Rear Main seal.
Has anyone changed the turbo in their CX-7??? Do you need to reprogram or can you just swap it straight out??Also any info on how to change a rear main seal or stop the leak would be helpful.Located Sydney, Australia
Old Jan 7, 2025 | 06:39 AM
Easiest option ( assuming diagnosis is correct ) is to remove the sub frame and drop the engine & transmission out the bottom as one unit.
Old Jan 23, 2025 | 02:59 PM
memelagos's Avatar
Your turbo shouldn't need to be reprogrammed. Always
check with your local dealer. Good luck man
Old Aug 18, 2025 | 07:11 AM
Luis's Avatar
I'm also in Australia, in Brisbane more specifically, and I had the same problem. It's a very difficult job to do at home, I had to send it to Lemans mechanics to fix it, the service will cost $1400. Right now my car is there.
Sr22
Dec 14, 2021 08:38 PM
Stolzie
May 1, 2019 02:24 PM
Nyeasha
Sep 7, 2018 01:55 AM
jaykirs
Feb 9, 2015 02:28 AM
